8 years agoCyclone V E Development Kit failed on Active Serial Configuration via JTAG
Hi All, I am currently working on Cyclone V E Development Kit. I tried to save configuration file into EPCQ256SI16N. I did follow the youtube https://www.youtube.com/watch?v=dpsfcgnqocu to gener...
8 years agoHi John,
Since the EPCQ device is connected to the MAX V system controller, I think the MAX V doesn't allow user to access the EPCQ device. This is documented for the Cyclone V GT Development kit here https://www.altera.com/support/support-resources/knowledge-base/solutions/rd02112014_88.html You may need to modify the MAX V image to gain access to the EPCQ device. I suggest you contact Altera support and confirm if you need to do it as mentioned in the link above. If this is not the case, you could also ask them how you can program the EPCQ thats on your V E Kit.
