8 years agoCyclone V E Development Kit failed on Active Serial Configuration via JTAG
Hi All, I am currently working on Cyclone V E Development Kit. I tried to save configuration file into EPCQ256SI16N. I did follow the youtube https://www.youtube.com/watch?v=dpsfcgnqocu to gener...
8 years agoHi,
It seems that your board has these already in place. Then I suggest you change the SW switch settings to reflect the AS mode. From the image you posted earlier, I see that the programming mode is in JTAG and not AS (note the JTAG signal chain TDI/ TDO). You need to change this mode to Active Serial in the upper right corner of the Programmer window. This will probably clear out the devices listed . You will have to add the EPCQ device again after changing the Programming mode. After the device is added successfully, select your .jic file and then the Erase, Program and Verify options and proceed. It should work this time.
