8 years agoCyclone V E Development Kit failed on Active Serial Configuration via JTAG
Hi All, I am currently working on Cyclone V E Development Kit. I tried to save configuration file into EPCQ256SI16N. I did follow the youtube https://www.youtube.com/watch?v=dpsfcgnqocu to gener...
8 years ago --- Quote Start --- Hi John, Please refer to the following manual for the Cyclone V E Dev Kit : https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/manual/rm_cve_fpga_dev_board.pdf The following is taken from the Cyclone V E kit manual: https://www.alteraforum.com/forum/attachment.php?attachmentid=14427 What this means is that, to use EPCQ device , you may have to rework the board with 10K resistors as shown in the figure. Before proceeding , please check your board if this configuration is already present. If so, then you just need to modify the SW settings and try. If not, then you need to get 10K resistors and wire the respective signals as shown in the schematic, change the SW settings and then try. -Abr --- Quote End --- 10K resistor is on the board. The problem is I kept failing programing the EPCQ Device by .jic file.
