8 years agoCyclone V E Development Kit failed on Active Serial Configuration via JTAG
Hi All, I am currently working on Cyclone V E Development Kit. I tried to save configuration file into EPCQ256SI16N. I did follow the youtube https://www.youtube.com/watch?v=dpsfcgnqocu to gener...
8 years ago --- Quote Start --- Hi John. 1. Make sure there are these three documents, schematic="C5E_DEV_KIT_B", Userguide="ug_cve_fpga_dev_kit", Manual="rm_cve_fpga_dev_board". 2. By default, this board support Fast Passive Parallel(FPP), sw1 from MSEL0 until MSEL4 equate to 0000. 0 means it is grounded, understand the schematic, it is at pg8 of schematic. https://alteraforum.com/forum/attachment.php?attachmentid=14431&stc=1 3. Why set 0000 at FPP which is default? Kindly study and understand, an example of one of the MSEL switch is given: Referring MSEL2 set to 0, it is using Flash. Flash(P30) means parallel programming. EEPROM(EPCS or EPCQ) means serial programming. This is the naming system, Flash=parallel, EEPROM=serial. Similarly, info MSEL0 is connected to MAX V can be found and so on. 4. Look at "rm_cve_fpga_dev_board" pg23, program using EPCQ, original text from that page has given the info, "In order to set the configuration scheme to AS mode, resistor rework needs to be done." Resistor rework=add resistor to the 3.3V that are applied to the MSEL0 till MSEL4 when dip switch is at 1111. 4a. This means user have to change the original grounded MSEL0 until MSEL4 into powered by 3.3V Vccpgm, but do not connect 3.3V directly and must connect 1kohm resistor to it. Use the breadboard to connect the 1kohm resistor. From basic electronics, that 1kohm is used to lower the current flow and help dispense heat in FPGA. 4b. This is simplified as it can be, do not skip resistor and direct put 3.3V to MSEL, it will damage the board through high current inrush, in this modifying case, it is not recommended for new learner unless user know how to modify connection. Last edited to grammar, remove all personal pronouns(I, You, We, They, etc), and picture into attachment. Best Regards, Tzi Khang, Lim (This message was posted on behalf of Intel Corporation) --- Quote End --- For MSEL is just for telling the FPGA Cyclone V know where will it load the configuration file. My problem right now is programing the ECPQ256. I have attached picture of error https://www.alteraforum.com/forum/attachment.php?attachmentid=14437
