10 years ago
Cyclone V don't work at low temperature
Hi,all
I design a digital image precessing board using the Cyclone V 5CEBA4U15I7N. It works well at normal temperature.
It don't work under -15℃ when there is no FPGA work current. But it's OK for the power voltage,power sequence and oscillator frequence under -15℃.
what's the reason?
Thank you for your reply.
Best regards.
Jimmy
    I check the other ICs. the problem come from the flash. The flash don't work at the low temperatur.
    Thanks for your suggestion.
    This part is rated to work even at temperatures under -15oC, so it should work.
    Are you sure that all the other ICs assembled on this board are really specified to work under such temperature ?
