10 years agoCyclone V ALTLVDS_TX: MSB inversion and timing constraints
Hello everyone, I'm designing a board with a Cyclone V driving a DAC running at 420MS/s using a parallel DDR interface. To achieve this datarate (840Mb/s per stream), there is an ALTLVDS_TX com...
10 years agoOk, I compiled the simplified design and run it on some test hardware and there is no such strange effect, a bit pattern of 1100 generates a signal with 50% duty cycle as expected. I had to use other pins and a lower frequency than on the real design though, so it may not be completely representative. No idea what's wrong there. At least I know that I must look out for this in future designs, as it could save some debugging.
Bye, Philipp
