10 years agoCyclone V 5CEFA4F23C8 has 24 DQ pins for LPDDR2 Hard Memory Interface
Hi. I am using the 5CEFA4F23C8 and LPDDR2 in a design, and I want to use the Hard Memory Interface for LPDDR2. I've noticed that the LPDDR2 hard interface has 24 dedicated DQ pins. That se...
10 years agoI think you are right, I read up on ECC in HMC/EMI documentation, and an additional 8 bits are needed for ECC. And now I was able to instantiate a 24-bit LPDDR2 UniPHY interface in Qsys when I turned on ECC.
So thank you very much for your reply, now I know why the interface is 24-bits, and if I ever need ECC I know what to do :)
