13 years agoCyclone IV PLL lock range: datasheet vs measurement
Hi, According to the Cyclone IV device datasheet, the: - PFD frequency (Fin/N) should range from 5MHz to 325MHz; - VCO frequency (Fin*M/N) should range from 600MHz to 1300MHz. When...
13 years agoHi FvM,
Here is the discussion: showthread.php?t=138. I originally wanted to insert a link, but I was not allowed to do so, as I am still a Beginner! According to this rule, you will see that Fpfd(min) is lower (x10 factor) than the specified's, too. I could undertand a difference by a x10 factor between the specified and measured frequencies, taking into account the PVT variations , as you stated. But a x1000 factor regarding Fvco(min), I cannot. Moreover, that: - the output clock is really stable (frequency, duty cycle, edges, etc...); - the measured Fvco(max) corresponds to the specified's. -> Is the Fvco formula right? -> Does the lock generation logic take Fvco(min) into account? -> Any further idea? Thank you for your collaboration! Regards, DEx.
