13 years agocyclone IV pcie ip core access host memory problem
Hi, I have a design with pcie ip core on qsys , and i use a pc(linux 32bits) to be host .now i want to achieve to use the ip access the pc memory through the txs signals . i connect the txs sla...
10 years agoHi
Thanks for your reply. Yes, my project is based on Qsys system. I have tried the above steps which you mentioned. From that I understand through "txs" we can access the host memory. So, I like to know is it "txs" of PCIe is accessing the DDR memory or some other internal memory?.(If you know how to see that, please help in it) If it is possible for you to share any reference design for the configuration we discussed. It will help me to access the host DDR memory.
