13 years agoCyclone IV not stable on my PCBs, completely stumped
I've got an EP4CE10F17C8 based design that I've recently moved from an Issue 1 PCB to an Issue 2 PCB, and now it's not behaving properly. Even a very simple configuration containing just a modulo 10 ...
13 years ago --- Quote Start --- Does anyone have any suggestions as to what I've overlooked? --- Quote End --- Clock noise (is the clock source routing the same?) (Are you using this raw or through a PLL?) Incorrect capacitors/ other components loaded in rev2. Floating reset input? ? Nial
