8 years agoCyclone IV not detecting on blaster
Hi All, I am working on an open source project using which is using cyclone IV EP4CE22F. Everything was working as per planned when all of a sudden my kit stops identifying on my laptop through ...
8 years agoHi,
--- Quote Start --- Hi All, I am working on an open source project using which is using cyclone IV EP4CE22F. Everything was working as per planned when all of a sudden my kit stops identifying on my laptop through USB Blaster. The kist is working as it is getting heated a little whereas the LEDs are not working which were linked to the code (I suspect the code got faulty but to update it I need blaster to work hence, a problem) IDK what happened which caused it this error. Anyone, please help! Thanks in advance --- Quote End --- 1.Is USB Blaster detectable by host machine (device manager->UBS controller->Alter USB-Blaster)? If NO. USB Blaster is damaged may be because of common ground issues Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
