13 years agoCyclone IV no JTAG access after PS configuration
Hi I use passive serial configuration for a EP4CE10F17C8 device (a DSP controls the nSTATUS, nCONFIG, DCLK and DATA0 ports of the FPGA) After configuration the FPGA releases CONF_DONE as it sho...
13 years agoI am getting similar issue on Arria V evaluation board as well but mainly by programming thru SignalTap. The only workaround I found so far is shuffle around the SignalTap buses, and re-compile. Next time around a good chance is it will work, but also a fairly high 25% chance more time to be wasted. My device is only about 1/3 full but it takes an hour to compile...
I wonder if the re-compile at least works for you. Jeng
