15 years agoCyclone IV M9K packed-mode RAM
Hello, I use the Megafunction of Quartus II to generate a single-port RAM. I implemented that IP at many places in my RTL design. After doing compilation, I expect that the resourse ultilizatio...
15 years agoI believe RAM packing occurs in the fitter, i.e. if it needs to the fitter can merge RAM cells into an M9K. If it doesn't need to though, it won't, as this provides more flexibility and better timing. Are you getting a no-fit? If not, you need to add more memories to see if it starts merging them. (Perhaps but a block into a LogicLock region that's small enough to require RAM merging)
