15 years ago
Cyclone IV goes into an undefined state
I'm using EP4CE10E22C8, in AS MODE. I have +1.2V supply for VCCINT and VCCD_PLL1,2; +2.5V for VCCA1,2, and +3.3V for all VCCIOs. MSEL2 and MSEL0 grounded. MSEL1 is connected to +2.5V. All these voltages are good. I delayed the VCCINT signal in respect to VCCA and VCCIO.
I noticed that after I supply VCCINT the nCONFIG signal goes low. Not only, but other signals (i.e. TDI, TMS) go low when theoretically they should keep on staying high.
    YES, NCONFIG, TDI and TMS are forced low by the FPGA and All voltages are good.
    Furthermore, even NCONFIG, TDI and TMS have pull-up resistors.
    nCONFIG is connected via pull-up to 3.3V and TDI ,TMS are connected through pull-up to 2.5V
    --- Quote Start ---
    Can I get information on power supply?
    --- Quote End ---
    As you're reporting "All these voltages are good", I don't see a need to discuss about the involved power supply. I have to assume, that the measurement is correct.
    --- Quote Start ---
    --- Quote End ---
    You mean, they are forced low by the FPGA? NCONFIG, TDI and TMS should have pull-up resistors, so are you sure, that the resistors are still supplied with 2.5 respectively 3.3V?
    --- Quote Start ---
    Do you want to say, the FPGA is working correctly if VCCINT isn't delayed? If it's working neither, I expect an elementary hardware problem, e.g. unconnected exposed pad.
    --- Quote End ---
    Sorry for my English:
    The delay is only an test
    MY PROBLEM IS that nCONFIG signal goes low. Not only, but other signals (i.e. TDI, TMS) go low when theoretically they should keep on staying high.
    I used these components:
    "MICROCHIP - MCP1825S" for 1.2Volt.
    "NATIONAL SEMICONDUCTOR - LM1117T-2.5" for 2.5Volt
    "LM2937-3.3" for 3.3Volt
    this component can be good?
