13 years agoCyclone IV E JTAG issues - VCCA voltage level
Hi all, I have a custom board with Cyclone IV E (EP4CE115-F484). I am trying to access it via JTAG from Quartus, but keep receiving the "Error: Can't access JTAG chain". I check the Quar...
13 years agohi,
"trying to go high" sounds not like there is a stable (even perhaps short) pulse but some rise in voltage which does not really reach anything near to a high level... This definitely - as there is nothing than the Pullup and the Pin being connected to the line - indicates the Cyclone not finishing POR. The question is "why?" Can you be 100% sure, that there is no mistake in layout or manufacturing that disconnects either on of the power or gnd pins (thus triggering the Built-In Brown-Out / Power fail detection reset) and that the pull-Up is wired to the Cyclone / the 2.5V? nStatus is bidirectional, thus if e.g. the Pull-Up is broken, not soldered correctly or not connected to VCCIO the missing "High" is detected and restarts configuration... Maybe worth checking... Is there anything connected to nConfig that externally resets the Cyclone (nStatus goes low with nConfig being driven low) or is nConfig initially going high and remains a stable High? Besides what's written in the handbook... I may have to recheck this, but iirc * nconfig goes high => reset condition removed * nStatus goes high => internal device reset "do this an that" completed, device can accept configuration data * Conf_Done goes high with device configured Even with no data (e.g. blank Config device or nothing by JTAG) the nStatus should stay high as long as there is no interrupt on the power lines... (having read through the configuration section I did not really found the magic 65µs...)
