13 years agoCyclone IV Device Selection Problem
Hi. I will try to usung Altera Cyclone IV E Device(EP4CE40F19A7N, 324pin) in my design. But Information about the device is not anywhere in site(pinmaps, package details..) Where I found that let ...
13 years ago --- Quote Start --- Altera Cyclone IV E Device(EP4CE40F19A7N, 324pin) --- Quote End --- You should contact an Altera FAE to see what they say. Personally I check for the most popular parts on Digikey as part of the selection process. For example, searching for the FPGA-324 pin package shows the EP4CGX30CF19C7N GX part is available, however, no E-series part. Although the handbook shows an E-series device in this package, I suspect it is just not popular, so probably not easily available ... if you are not planning on placing a large order, I would recommend selecting a more popular part (where popularity is determined by the availability/price on Digikey). You do not have to order from Digikey, Arrow also stocks these parts, however, the Digikey site has a decent enough search engine and provides stock counts. Cheers, Dave
