15 years agocyclone IV backwards compatible with cyclone III
Hello, I have a question about cyclone, i am new with FPGA. Is the Cyclone IV backwardscompatible with cyclone III and II. I need to make choise between two development boards. If the cyclone ...
15 years agoIn what way do you needs backwards compatability? They wont be pin compatible because of different packages. But unless you have specifically instantiated Cyclone 3 elemements in your code (which most people wont be doing) the code should port across the two chips as easily as just changing the device type (and pin allocations) in a quartus project. No source code changes needed.
