13 years agoCyclone IV - Using high impedance in GPIO
I have a project with 14 bidir. I use to test integrated circuits from college. i use the 36 gpio pins in a protoboard with a flat cable. but when i put the bidir in high impedance, all output...
13 years ago --- Quote Start --- So, why can I do? --- Quote End --- What's the problem? If you need them low add very high value pull down resistors from each line to gnd. ? Nial
