15 years agoCyclone III stuck at POR?
Hi, I have problems to get a custom board work, the FPGA seems to be stuck in POR. It's a PCIe card with a EP3C10F256C7N. I attached an excerpt of the schematic to this post. I have 10 pro...
15 years agoExposed Pad pin 145? I missed this. I went back and found reference to it in these locations...
- AN 466: Cyclone III Design Guidelines, Page 3, note (5) "The E144 package has an exposed pad at the bottom of the package. This exposed pad is a ground pad that must be connected to the ground plane on your PCB. This exposed pad is used for electrical connectivity and not for thermal purposes." - Pin Information for the Cyclone III EP3C5 Device, page 7, note 3 "The E144 package has an exposed pad at the bottom of the package. This exposed pad is a ground pad that must be connected to the ground plane on your PCB. This exposed pad is used for electrical connectivity, and not for thermal purposes." - Altera Cyclone III Handbook, Chapter 1, Page 1-4 "The E144 package has an exposed pad at the bottom of the package. This exposed pad is a ground pad that must be connected to the ground plane on your PCB. This exposed pad is used for electrical connectivity, and not for thermal purposes." footprint information - http://www.altera.com/devicepackaging/04r00221-02.pdf I think I can salvage these protoboards with a little bit of solder work since it calls for electrical connectivity and not thermal performance. I'll report back early next week and let you know for sure that this worked for me. I'm sure it will. Thanks so much for noticing this.
