15 years agoCyclone III stuck at POR?
Hi, I have problems to get a custom board work, the FPGA seems to be stuck in POR. It's a PCIe card with a EP3C10F256C7N. I attached an excerpt of the schematic to this post. I have 10 pro...
15 years agoThe POR circuit keeps the device in the reset state until the power supply voltage levels have stabilized after device power-up. After device power-up, the device does not release nSTATUS until the required voltages listed in Table 9-4 on page 9-8 are above the POR trip point of the device.
For the Cyclone III, voltage that must be powered-up are VCCINT, VCCA, VCCIO (for the banks in which the configuration and JTAG pins reside) In my application I have the following voltages: VCCINT 1.2 (actual is 1.209) VCCA 2.5 (actual is 2.508) VCCIO 3.3 (actual is 3.255) So, I believe I have the voltages required.
