15 years agoCyclone III stays in POR forever
I'm using EP3C5E144, and tried download code through JTAG and configuration port without success. I found the pins nSTATUS, nCONFIG and CONF_DONE are all logic low. Does this mean the chip is in Powe...
15 years agoThanks, you guys. These pins are pulled up with 10K resisters already.
By reading another thread, I found out that the E-PAD under the chips was not soldered to GND very well (cold-joint). Now the problem has been fixed. Have a good day.:)
