9 years agoCyclone III not configuring, using AS.
I'm currently using Cyclone III (EP3C5F256C8) and I'm trying to configure it and it's not happening. I'm using AS connected to a FLASH chip (M25P16). nCONFIG, nSTATUS, CONF_DONE and INIT_DONE are pul...
9 years agoThe design has a socket where I plug-in the Flash. The flash is loaded with the .rbf through a BK precision programmer, then plug it to the board. I suspected that maybe the data was corrupted and had a wrong header, but when I went in with the logic analyzer at least the first 50 bytes looked correct.
