18 years agocyclone iii +jtag and prom interface
i am doing a project using altera cyclone iii fpga. i need to connect jtag and also the serial configuration device. i have referred the hand book available in the site. but there is a bid confuse on...
18 years agoThe said EPCS controller is named SFL (serial flash loader).
--- Quote Start --- You can either program the flash with the Flash Programmer GUI in the NIOS 2 IDE (you don't need a nios core for that) or from the nios2 command shell. --- Quote End --- For general designs (non NIOS II), the programming can be done from Quartus II programmer.
