13 years agoCyclone III FPGA Temperature Measurement.....
Hi All, I want to measure the temperature across the cyclone III fpga. Is there any inbuilt sensor is available for the temperature measurement? If yes please let me know the procedure t...
13 years ago --- Quote Start --- We are planning to measure the board temperature instead of measuring the die. --- Quote End --- Then that is fairly simple. Are you designing a board, or do you already have a board? If the board has a board-level temperature sensor, then all you need is the read the sensor, eg., using I2C or SPI (two common interfaces for sensors). Provide a little more detail, and I'll point you in the right direction. Cheers, Dave
