13 years agoCyclone III FPGA Temperature Measurement.....
Hi All, I want to measure the temperature across the cyclone III fpga. Is there any inbuilt sensor is available for the temperature measurement? If yes please let me know the procedure t...
13 years agoHi Frank,
--- Quote Start --- You can measure temperature by forward biasing a substrate or PCI clamp diode. --- Quote End --- Have you ever implemented such a circuit? Any details? An FPGA thermal diode is usually a diode-connected transistor, which can be sensed by say an ADM1032 I2C device http://www.onsemi.com/pub/collateral/adm1032-d.pdf I thought I'd read a warning not to use regular diodes for this application ... How would you use a clamp diode in this manner? You'd have to raise the current-source voltage above VCCIO so that the diode conducted right? Cheers, Dave
