13 years agoCyclone III FPGA Temperature Measurement.....
Hi All, I want to measure the temperature across the cyclone III fpga. Is there any inbuilt sensor is available for the temperature measurement? If yes please let me know the procedure t...
13 years agoThe pin connection guidelines for the Cyclone III:
http://www.altera.com/literature/dp/cyclone3/pcg-01003.pdf Do not list THERM_P/THERM_N pins. This means there is no thermal diode. You could check the pinout for your specific part (which you did not state): http://www.altera.com/literature/lit-dp.jsp?category=cyc%203&showspreadsheet=y However, you're probably not going to be able to measure the die temperature. The best you can do is measure the case temperature using an external device. Cheers, Dave
