13 years ago
Cyclone III FPGA Starter Kit
Hello
I installed "Cyclone III Starter Kit" and played with the initially stored program (in which LEDs blink) using Board Test System.
But now I am wondering where I can get the project file(qpf) of this initially stored program.
I thought the project file named "cycloneIII_3c25_start_niosII_standard.qpf" is it but when I compiled the file I faced an error telling me "Error (12006): Node instance "comb_4" instantiates undefined entity "cycloneIII_3c25_start_niosII_standard_sopc."
So the question is
Can I see the preloaded program of Cyclone III Starter Kit?
and if "cycloneIII_3c25_start_niosII_standard.qpf" is the one I should look for, can you tell me how I can compile it?
    Hello, Jean-Michel
    Sorry for late reply. It had been winter break.
    --- Quote Start ---
    All 4 leds come turned on.
    But what does it make? I can push any button ; nothing changes. Do I need some extra hardware beyond the cyclone III started kit? Do I need some Nios II Embedded Evaluation Kit?
    --- Quote End ---
    Is "Board Test System" installed under the folder named "Cyclone III EP3C25 Starter Kit v12.0.0" ?
    If not, follow the "User Guide" (there should be an instruction of installing "Cyclone III EP3C25 Starter Kit v12.0.0").
    --- Quote Start ---
    Anyway, where to find more tutorials about this cyclone III starter kit?
    Tutorials or project files for education purposes. Self-speaking project files.
    There is no my_second_fpga my_third_fpga my_fourth_fpga, is there??
    Is there some file server somewhere on internet where to download project file. Easily understandable.
    --- Quote End ---
    I think there is no additional "my_****_fpga" programs nor tutorials about the kit.
    However, it is useful to refer to free online trainings which are available on the Altera's website.
    --- Quote Start ---
    Tutorials involving the fpga + the buttons + the leds + the memories on the board.
    Tutorials involving floating point and fixed point arithmetic operations.
    Understandable tutorials.
    Tutorials executable by this Cyclone II starter kit.
    Tutorials understandable by a beginner.
    --- Quote End ---
    I think Altera is quite unfriendly to beginners...
    Good luck with your kit.
    Hope my reply would help.
    Yukihiro
    Hello Yhatagishi,
    You use the same kit as me. You reached the same milestone as me. I could compile and execute this "cycloneIII_3c25_start_niosII_standard" on my cyclone III starter kit.
    Thank you in advance.
    Jean-Michel.
    Dear Cris72
    Thanks for your reply.
    I just tried the way you told me and could compile the "cycloneIII_3c25_start_niosII_standard."
    I appreciate your help!!
    --- Quote Start ---
    Probably you need to rebuild the sopc system, in order to generate the requested entity.
    You should have in your standard project a *.sopc or *.qsys file.
    Launch Qsys and open this file, then generate the system. This should create the missing files.
    --- Quote End ---
