15 years agoCyclone III FPGA power supply problem
hello, i am working on fpga based project. i m using cyclone3 fpga. in dat we hav 1.2v n 3.3v supplies necessary for i/o operation. we are using two TPS54310 ic's for both the supplies. we connect...
15 years agoYou are right about TPS54310, for some reason i didn't find it. But it's basically identical to the TPS54311 I mentioned.
--- Quote Start --- the capacitor(6.8uF) we are using across the inductor(2.2H) at the output. --- Quote End --- Your additional explanations don't make much sense. No switch mode regulator uses an inductor of 2.2h. Do you mean µh? I also can't see, how a capacitor will be connected across the inductor. --- Quote Start --- pin2 is VSENSE its voltage range is -0.3v to 4v which is coming around 0.4v --- Quote End --- Do you mean, there is no stable measurement at all? --- Quote Start --- Vout is 0v. --- Quote End --- In this case, Vsense would be 0V as well, presuming a correct circuit and correctly performed measurement. Two questions from my previous post are unanswered yet. --- Quote Start --- Did you try to disconnect the load? You should show a complete schematic. --- Quote End ---
