15 years agoCyclone III FPGA power supply problem
hello, i am working on fpga based project. i m using cyclone3 fpga. in dat we hav 1.2v n 3.3v supplies necessary for i/o operation. we are using two TPS54310 ic's for both the supplies. we connect...
15 years agoIt's not actually a question related to Altera FPGA. Anyway...
TPS54310 doesn't exist. Do you mean TPS54311? --- Quote Start --- pin17 shud be 2.7v but we r getting 2.8v --- Quote End --- Read the datasheet once again. --- Quote Start --- pin2 shud be 0.9v but we r getting 0.4v --- Quote End --- You either overload the 3.3V node or your circuit is wrong somehow. Did you try to disconnect the load? You should show a complete schematic.
