18 years agoCyclone III DDR problem. Need help
I am trying to use 32MB DDR with cyclone III starter kit. But when i try to compile it gives me error saying "The DQ group with DQS pin has invalid DQ group assignment" Can anyone help me with thi...
18 years agoI guess, you instantiated the core manually? I can only say that the qb3_control_panel project, that uses DDR2 can be compiled as shipped with the starter kit. (I don't have the starter kit, I just compiled for trial.
It may be generally more easy to modify an existing example project, cause it contains all necessary definitions including pin assignments with termination etc. If you start a project with DDR HP controller from the scratch, you should follow the directions from Megawizard regarding execution of TCL scripts to make all necessary settings.
