13 years agoCyclone III configuration with EPCS4 issues
Hi all, I need your help concerning an issue of serial flash configuration . I have cyclone III FPGA (EPC3C16) connected on a board with the serial flash EPCS4. I have only one header(JTAG)...
13 years agoAre you sure that you connected the flash to the correct FPGA programmation pins? Did you generate the .jic with the correct flash reference (EPCS4)?
