15 years agoCyclone III and SA58631 mode pin
Hi
a short background info: the SA58631 is an audio amplifier from NXP. it has a mode pin with 3 states. 0 to 1.5V = on 1.5V to Vcc - 1.5V = mute Vcc - 1.5V to Vcc, or pin left floating = off. in my system the SA58631's Vcc = 7V and the FPGA Vio is 3.3V. it made sense to me that I could control the chip using an IO at 0 (on) 1 (mute) and tri state (off). I also added a 1K series resistor between the IO and the amp for buffering. in realty, when I use the tri state option, the device is in mute. the amp mode pin is at 4.5V. I expected an internal weak pull up inside the amp to set Vcc on the pin. could it be that there is some clamping diode on the IO? any assignments I can use to fix that? thanks in advanceNo RepliesBe the first to reply
