15 years agoCyclone III and EPCS4
Hi, i am trying to start Cyclone III with EPSC4. I write VHDL code wich toggles one of FPGA pins, but nothing happens, Quartus is programming the flash device - programmer says that everything is ok,...
15 years ago --- Quote Start --- They didnt mention that all of VCCIO should be connected --- Quote End --- See POR chapter in Cyclone III hardware manual. In your design, both bank 6 and 7 are driven from 1V8 volt. --- Quote Start --- Cyclone III device family contains POR circuitry to keep the device in a reset state until the power supply voltage levels have stabilized during power up. During POR, all user I/O pins are tristated until the VCC reaches the recommended operating levels. In addition, the POR circuitry also ensures the VCCIO level of I/O banks 1, 6, 7, and 8 that contains configuration pins reach an acceptable level before configuration is triggered. The POR circuit of the Cyclone III device monitors the VCCINT, VCCIO, and VCCA pins during power-on. The enhanced POR circuit of the Cyclone III LS device includes monitoring VCCBAT to ensure that VCCBAT is always at the minimum requirement voltage level. --- Quote End ---
