15 years agoCyclone III & SDRAM
Hello everybody. the situation: we have Cyclone iii(EP3C25Q240C8) and sdram(MT48LC4M16A2) are connected directly. Clk from board 24MHz plled to 100. need to do : write data block to RAM and re...
15 years ago --- Quote Start --- I suspect the read data-path has been optimized out. Quartus II is quite intelligent about that, e.g. even if you connect a RAM to the read-data output from the SDRAM controller, but no logic is reading that RAM QII will optimize the complete chain away. --- Quote End --- Yup -- do something with all the bits from each read and then output the result to a pin. XOR will do.
