19 years agoCyclone II programming problems
Hi all -- I've built a few PCBs based on Cyclone II FPGAs. Some of these boards, and especially the last, suffer from an annoying problem: When connecting the FPGA to the JTAG cable, Quart...
19 years agoYou might double check all your pin connections (i.e. VCC, GND, clocks, etc). Also, the QII software will configure unused I/O as "Output Driving Ground" which can be a big problem if one of these pins happens to be tied to VCC. You might try changing the unused I/O to "as input tri-stated" and see if this makes any difference.
set_global_assignment -name RESERVE_ALL_UNUSED_PINS "AS INPUT TRI-STATED" Is the part hot to the touch before "powering down" (unless it is programmed as such, there is no power down / sleep mode that I'm aware of). Considering the programmer is telling you the device is configured successfully, I think it's time to look at the pin connections and/or the design(?)
