19 years agoCyclone II programming problems
Hi all -- I've built a few PCBs based on Cyclone II FPGAs. Some of these boards, and especially the last, suffer from an annoying problem: When connecting the FPGA to the JTAG cable, Quart...
19 years agoI've checked the signals you indicated. The nCONFIG pin is pulled high, but as I had not installed a programming device, I had the DCLK pin floating. Both MSEL signals are shorted to ground.
However, shortingthe DCLK to ground did not change the situation. I removed the short, and installed the serial programming device, did not solve it either.. To make it even more strange, after 3 minutes or so, the FPGA enters some sort of power-down more by reducing its current drain by 40mA, making it unable to detect in QuarutsII using JTAG. Again, all comments/thoughts are more than welcome!
