19 years agoCyclone II programming problems
Hi all -- I've built a few PCBs based on Cyclone II FPGAs. Some of these boards, and especially the last, suffer from an annoying problem: When connecting the FPGA to the JTAG cable, Quart...
19 years agoRefering to the configuration scheme on page 13-63, have you followed the notes below the figure? Particularly, Note 2:
(2) The nCONFIG, MSEL[1..0] pins should be connected to support a non-JTAG configuration scheme. If only JTAG configuration is used, connect nCONFIG to VCC, and MSEL[1..0] to ground. Pull DCLK either high or low, whichever is convenient on your board. Regards, Chris
