18 years agoCyclone II: how to delay output to pin?
Is there any way to delay the data output to a pin? I have tried all possible settings in Quartus II and the only way to delay (around 4ns) seems to be to use LCELLs. Also, i'm seeing that an input p...
18 years ago --- Quote Start --- I have used LCELLs in the past but since the timings may change with temperature, chip batch etc it seems unreliable. How much can the LCELL delay change between chips? --- Quote End --- This is why I said to be sure to analyze the timing for all timing models. That will cover the timing variation over PVT.
