18 years agocyclone II : dual port dual clock memory possible?
There is any workaround to this problem? Error: M4K memory block WYSIWYG primitive "vram8k:vram8k_inst|altsyncram:altsyncram_component|altsyncram_3s62:auto_generated|ram_block1a0" utilizes the ...
18 years agoYou have to add a default parameter in Analysis & Synthesis Settings, as described in the Cyclone II Errata Sheet (shown as respective tcl command)
--- Quote Start --- set_parameter -name CYCLONEII_SAFE_WRITE "\"RESTRUCTURE\"" --- Quote End --- The memory consumption is however doubled by this workaround. For known fixed devices, another setting exists.
