dkurgs's avatar
dkurgs
6 years ago
Cyclone 10GX Differential termination
Greetings all,
we are designing a PCB including the Cyclone 10GX220 and were slightly confused by the datasheet.
We wish to terminate an incoming LVDS pair using the normal 100 Ohm differential termination (the datasheet calls it RD).
Do we still need to calibrate the OCT? Should we still connect an external OCT calibration resistor to the bank's RZQ pin?
Thanks!
  • Hi Daniels
    Thanks for your inquiry.
    If you have the OCT enabled for the FPGA, you do not need external termination. There is no calibration needed for Rd OCT.
    Eng Wei
  • EngWei_O_Intel's avatar
    EngWei_O_Intel
    Hi Daniels
    Eng Wei
      EngWei_O_Intel
      Hi Daniel
      Eng Wei
