Cyclone 10 GX IBIS models
- 3 years ago
Please refer to the attached screenshot, where I got from the visual IBIS software. It shows that in the model there is 50-ohm terminations, I believe.
Aqid
ibis models have been tested the correctness, so you can follow it.
May I ask what's your simulation process and how to judge OCT is not included?
BR,
Mengzhe
- fkeflkafakawfkawlfja3 years ago
Hi, thanks for the reply.
I used a generic 1.8 V driver that is included in SigXplorer. Then I connected the driver output to a 50 Ohm characteristic impedance stripline that is 6 inches long. Then I created a bidirectional driver/receiver (IO) set to tristate mode so that I could use the 18_rtio_r50_hv model, and connected this to the other end of the stripline.
When I drive a square wave at 100 kHz I was getting extremely large overshoot at the receiver, for example around 2.5 V for the 1.8 V signal.
