14 years agoCyclon IV GX transceiver Starter Kit - PCI Express
Hi guys, I have bought this developement kit and i want to test the PCI Express port. I was using the Board Update Portal to load a *.flash into the FPGA and test it but i couldn´t get i...
13 years agoHi All,
I have tested the PCIe ref design succesfully on the starter kit. Initially i faced problems while installing the jungo driver and detection of PCIe. But later i managed to test the ref design. First i have installed the jungo driver and then connected the board to the PCIe slot of the PC. Then i loaded the .sof file. While programming first i have done auto detect and two devices appeared. selected the CycloneIV and when i right click i have options to change the programming file and i have changed the programming file with that of the ref design. When the GUI appeared on the PC it was showing Stratix IV (may be default) then i restarted the sysytem (dnt shutdown since .sof file will be erased) and then i could able to see the CycloneIV details. The ref design i was using is PCIe endpoint onchip memory. I could able to write to and read from the memory.
