14 years agoCyclon IV GX transceiver Starter Kit - PCI Express
Hi guys, I have bought this developement kit and i want to test the PCI Express port. I was using the Board Update Portal to load a *.flash into the FPGA and test it but i couldn´t get i...
14 years agoThanks for the answer Jversay.
But i still have the problem. When i am downloading the files, even if i tried to download the *.flash file (in HW browser) or i download *.sof file (in SW browser) , the red led meaning error is shining. Still, i continue making all the steps,i press the PGM buttoms... i change as well the S8.2 (USER_PGM) as you have told me, and i run the BTS. Then, i select the configuration mode i want, but the BTS is like block. The message "Starting the FPGA" appears, but it is not changing... the initiation stays at 0% I have wait 5 minutes, but nothing is happening. any other suggestion???? thanks. Lucia
