13 years agoCYCLON IV GX - ALTGX Won't recieve any valid data
Hello I'm new in the forum, seems like very nice one me and my partner working on a final project for the university engineering degree. We have designed and manufactured two printed circu...
13 years ago --- Quote Start --- so yeah, I checked with modelsim and it works fine, we will review our code again and see maybe the physical layer is doing some troubles. --- Quote End --- Set your transmitter pattern to something slow enough that you can see it with a scope, and probe the RX pins. Check you're not missing something obvious, eg., the correct pin assignments, or a missing termination, or power supply voltage. Also check to see whether you need to AC couple the links. If you're testing FPGA-to-FPGA, it should be ok, but if you're interfacing to something else, then check the common-mode voltage is compatible. Cheers, Dave
