13 years agoCyclon III + EPCS16 programming
Hello, I'm quite new to Cyclon FPGAs. Just got my new custom board made and was happy that it JTAGed using TerasicBlaster and FPGA works fine. The problem is that program is not reloaded ...
13 years ago --- Quote Start --- In quartus programmer I only see one device whic is cyclon. I'm starting to wonder - Is it actually possible to program EPCS16 using TerasicBlaster? Or is it just Cyclon FPGA thats gets the program. I can't select EPCS16 as a device in Quartus Programmer, because the project is done for Cyclon and programmer says that sof file is incompatible. --- Quote End --- Select the Cyclone device in the Programmer window. Then select "Attach flash device" from the Edit menu or in the context menu (mouse right click). At this point I can't remember exactly but I think you need a different file format assigned to epcs: jic or pof. sof is intended only for jtag configuration and it is not the actual format stored into flash.
