15 years agoCustom Component Address Mapping
I have a custom component with a 8 bit ADDRESS bus. it is mapped in my hdl code this way : .... if (read & (address==8'h01)) readdata<=2; .... In my SOPC builder system i...
15 years agowith
--- Quote Start --- unsigned char a=IORD(componenet_base,0x10) --- Quote End --- The CPU will do one 32-bit read access to the component's register 0x10, which the switch fabric will change into 4 8-bit read accesses at registers 0x40,0x41,0x42 and 0x43 (notice the register number shift). It's a lot easier to do a 32-bit data bus, even if you only use the low 8-bits. It will save you a lot of trouble.
