15 years agoCustom Component Address Mapping
I have a custom component with a 8 bit ADDRESS bus. it is mapped in my hdl code this way : .... if (read & (address==8'h01)) readdata<=2; .... In my SOPC builder system i...
15 years agoyea my data bus is 8 bits wide!! is this problem independent of the size of the variable we assign IORD to ? for example whether we use:
""unsigned char a=IORD(componenet_base,0x10)"" or ""int a=IORD(component_base,0x10)"" the cpu does 4 read actions? (assuming the cumponent's data bus width is 8) ? another questions : my compent has an 8 bit address bus. how is my 8 bit address mapped into the 32 bit Nios address bus ? the 32 bit address is truncated to an 8 bit address bus?
