15 years agoCurrent Consumption of VCCA pin for CIII-25
Hello people, On my project, i have 8 CIII-25 fpga's running parallel. Fpgas will run over 100 MHz full performance with almost of the logic elements are used for switching. I don't k...
15 years ago --- Quote Start --- There will be 8 CIII-25 fpgas on the board. - what can the total current needed for 2.5V line? i could not see any info on the device handbook. --- Quote End --- I found on CIII datasheet that current for VCCA is about 8mA. Then for 8 devices a 100mA supply could be ok. --- Quote Start --- - Can you advise me a LDO from 3.3V to 2.5V. --- Quote End --- There are a lot of devices good for this. Browse the selection guides from any vendor website (Texas Instruments, National or Linear Technology have plenty of LDOs) and then choose one based on availability from your local distributors. --- Quote Start --- - We won't need ferrite beads if we use LDOs right? (although 8 fpgas will be supplied from the same LDO output?) --- Quote End --- Probably ferrite beads are not strictly needed when you use a dedicated supply for analog circuitry. Anyway I think placing the ferrite + capacitor filter near the VCCA pins is still recommended; infact, even if 2.5V is not shared with any digital supply, connecting it to 8 fpgas will require rather long traces which could pick up high frequency noise, especially if you can't route them through a dedicated pcb plane.
