15 years agoCrystal Clock at EPF10K100EQC240-3
Hey, I am using EPF10K100EQC240-3 IC with 8MHz crystal (SG-615P). When I measure signal on the crystal I see only 60Hz (in my country the frequency of AC power is 50Hz) instead of 8MHz. The ...
15 years agoHow did you measure your clock signal? Did you use a scope? What does the waveform look like? Are you sure you have a good ground connection?
