15 years agoCritical Warning: Timing requirements not met
Hi everybody, When i compile my design on Quartus II, it gives me the following errors: "Critical Warning: Timing requirements are not met." "Critical Warning: Found minimum pulse wid...
15 years agoThank you very much. When I defined the clock by the create_clock and derive_clock_uncertainty commands, the warnings gone.
